I bought a rx7 three years ago and have since rebuilt the car from the ground up, put in a s5 13b turbo, completely overhauled the interoir, 18" mags, custom paint job, custom bodykit and lots of electronics and motor upgrades. Over $15000 was spent.
Two weeks ago i received a letter from savings and loans saying i must surrender the car to them due to an unpaid loan. i didn't understand this because i paid for the car outright. when calling them they told me that a loan was taken out six years ago for the car by a past owner and $5900 was still owing.
After seeking legal aid i was told i could either pay them $5900 or surrender the car. due to financial diffuculty as i am now a uni student and no family member or friend willing to help me out i had to give up the car.
Legal aid asked why didn't i get an encomberance (outstanding loan) check done on the car when i bought it. being ninteen i had no idea such a check could be done.
I have found out now that checks can be done for $10 at any registration department.
If you or anyone you know know is buying a car privatly or through a car yard, get this check done, even if you know the person you are buying the car from.
I will keep every one posted on what happens.
Thanx for taking the time to read this.
https://www.sau.com.au/forums/topic/35244-read-this-encomberance-checks/
Woah, feel sorry for ya man. Usually if you are buying a fast car from a young bloke there is the possibility that it may be out on a massive loan - always do a Revs check on the intended purchase (Is the safest way - as Blackdoggette mentioned) There is also a point where if there is money still owing by the seller and the loan is not registered with Revs you can purchase a certificate from em to barr any repossesion from a loan credit place or bank. I assume this was private sale? Private saleis the easiest way to get a bargain & also the easiest way to get into trouble. Watch out there are plenty of shady private sellers out there! Hope everything works out for ya. Fingers crossed!
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
