As the topic suggests, i have a RB26 head here, this was removed from my car, 1994 r32 GTR.
head was removes as one stock turbo failed and marked number 5 bore in the cylinder, engine was low on compression so the head was separated. I purchased a whole new engine, hence not needing the head any longer. The head is in good running condition, still assembled ready to bolt up.
Head includes cams and all associated hardware, valves etc and cam covers, backing plate, cam gears
looking for $1000 can post at buyers expense, shouldn't be much.
Also have full plenum/throttlebody setup, coil packs and brackets and other parts covers etc, that can be purchased separately
https://www.sau.com.au/forums/topic/352793-rb26-head-with-cams-and-covers/
also have injectors, rail, fpr(all stock gtr gear) and low mount manifolds, turbo dump pipes, incase someone is chasing a whole setup. have almost evertyhing except the turbos themselves
phone number 0408275902, but easiest to just reply here or PM me.
cheers simon
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
