Wtb - Rb26 Power Fc - Or Other Ecu - Gtr Turbo Kit - Injectors, Daily Car
looking for pref a power fc or something else to suit rb26
maybe some big injectors aswell
or maybe a turbo kit, t76 or t78, prefer single and full kit
or a daily car, pref man, nsw rego
i have a set of four white defi guages and controller
and a set of white 18' TE37 rims
check my for sale ad's for more details :)
cheers
0467505670
We've got some great deals going with T51R turbo kits, they can be found within our trader section using the following link:
http://www.skylinesaustralia.com/forums/topic/326240-hks-turbo-clearance-unbelievable-prices/
cheers
0467505670
i have a GT garrett turbo for sale going cheap if interested
i have a 32/33 gtr power fc with hand controller and some 800cc inj not flow tested. hills district sydney pm or call me if keen 0431445349 dan
would trade for the four defis and controller and the guage surround. what size are the guages,with cash my way
  • 6 years later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
