K all itens are located in wollongong which is about an hr south of sydney
Hi there i have some stuff in my gurage that i dont need anymore so here is a list and prices, also all stuff is located in wollongong and is pick up only:
- R33 rear brake pads in ebc green stuff $100 ( only done less than 3000km, also will fit 300zx and wrx with twin piston rear)
- stock r33 suspension $60
- R33 steats series 1 $50 (pair)
- eg civic front pads $20
- eg civic rear shoes $20
- R33 tail lights with trim $50pair
- R33 boot lid in gunmeatal grey $60 (for series 1)
- R33 series 1 rear spoiler $20
- CH lancer right rear tail light $40
More stuff to add soon
https://www.sau.com.au/forums/topic/353300-random-stuff/
still got them seats? any tears or bits missing?
Edited by Tomr33gtst
https://www.sau.com.au/forums/topic/353300-random-stuff/#findComment-5720921
    • I didn't think about how a circle works before, dumb.  Before, I had .9mm restrictor bolts but I can't use these cause they were shorter aluminium bolts that just tear off their threads when tightening since the OEM lines are thicker than the shitty braided one that was installed previously. Now I use longer 1mm stainless steel restrictor bolts. I think the difference will not affect the health of the turbos, but I guess I'll have to drill out the main feed bolt as I agree multiple restrictions sound dodgy. The one that was installed with the braided line was just too short, but completely without a restrictive hole.
    • Tomei or Nitto, don't use the OEM one or Cosmetic ☺️
    • After cleaning up a rusty cooling system in a 33 gtst that's been sitting for years it seems to have cleaned out the head gasket too haha. It seems the Tomei metal gasket works without machining surfaces? Or put oem? Also should put an oil restrictor while the head is off? Thanks
    • Thanks, I definitely saw the more expensive options from Crank and driveshaft shop. Thank you for the D-max option.  Still hopeful someone has an OEM out of the box option I found that the 300zx NA Left drive shaft is a good match for the Right on the R33. https://www.gsplatinamerica.com/product/ncv53040 Just need to find Left CV for the R33, I cannot find any <=22" axles.
