G4 Suspension $700
Mono tube large valve design, Adj damper and height
Autech Catch Tank $130
Carbon Intercooler surround(nissan/nismo) $170
Has a couple of small marks
R33 GTR Front seat belts (vvg condition) $100
FRP N1 bumper vents $100
Boot interior rear plastic cover $40
Steering wheel surround $30
Instrument cluster surround $20
Series 3 rear "Skyline" panel in KH3 black $120
R33 s1 4 door center panel $80
R33 S1 4 door passenger tail light $150 (drivers side slightly damaged-not the lens...can have free)
R33 GTR Vspec Rear CV's(pair) $180
R33 GTR 24U Air Diversion Panel $80
located in Adelaide. can post
Matt
0413023669
SOLD
carbon intercooler duct
Diversion Plate
Catch tank
Steering wheel cover
Still Avail
G4 Suspension $700
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
