this afternoon i was just playing around with my bov and adjusted too loose and the cap flew off.. and a few pieces flew out.. spring and cap thingy.. luckily the bonnet was open and i picked the pieces up (spring, metal bottle cap thingy) and screwed them back in.. afterwards i've been experiencing a rough idle and it seems to want to stall.. am i missing a few pieces on my bov?? i've been told i might have a leaking bov.. how might i fix it? Thanks
btw this is on an sr20det 180sx
https://www.sau.com.au/forums/topic/35379-leaking-bov/
have you got the pieces around the wrong way, i did this to my bov aswell unscrewed it too much and it went everywere and I put it back the wrong way so the gold bit that moves up and down was up the wrong way
if thats not the cause have you tightened it enough? , and no your not missing anything
mine had BOV spring , BOV copper gold thing(botle cap) , the top and the bottom ,
failure to that you may have damaged/ bent your spring? does it look ****ed?
i eventually put my stock bOv back on becuase the aftermarket was shit
not sure if its the same on a 180 but the r33 stock bov is mint
give me a PM if its not it and ill try and figure it out by looking at mine for u/ le tme know how u faired
https://www.sau.com.au/forums/topic/35379-leaking-bov/#findComment-706551
air travels up on bov's
____
| | < spring
| < exits /
______| |________| |
_ _ _ _ ^ _ POD |
___________________ /
INTAKE
as air reverts back out it forces the cap thing up via air pressure and lets it out as the spring counteracts , so if you have in fact inversed it (flipped it) then its letting out air without any resistance e.g if cap is at top spring at bottom
https://www.sau.com.au/forums/topic/35379-leaking-bov/#findComment-706607
the more air it lets out the less is going back towards the turbo , i didnt really notice any difference between tightening it / loosesning it , i would tigten it on a scale of 1 - 100
1% being loose and the top blowing off
100% tight as can make it
on the line it was about 70% i found it the best
so tight just not super tight
seems to do both release air + make a nice noise tight noise not fluttery
thatway you know its releasing it in 1 go not little bitts (fluttery)
https://www.sau.com.au/forums/topic/35379-leaking-bov/#findComment-706694
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
