1989 R32 GTST Sedan
Manual White
rego till april 2011
Full Regency inspection
Engine rb20det
185xxx kms on clock..155xxx on engine
Power FC
Gtr injectors
Garrett hiflow turbo custom made by Rotomaster
full 3inch turbo exhaust and hi flow cat batmbl split front/dump, xforce 3inch cat convertor and tanabe medallion catback
splitfire coilpacks
JJR return flow intercooler setup
Walbro 500hp fuel pump
Apexi cam gears
Gates racing timing belt
Standard airbox with blitz panel filter
Gtr bov
MSpec dual core alloy radiator
extedy HD clutch
Suspension & Braking
Largus coilovers (jap brand)
8kg fronts and 6kg rears
32 point damper adjustable
Height adjustable
(have the adjusting spanners)
Front strut brace
Alloy steering spacer
15000km old rda rotors on front
QFM A1RM pads
Hicas lock bar/hicas lines and pump completely removed
Wheels
Rota D2
18 x 9 +30
235/40 goodyear eagle f1 all round
Exterior
Vertex side skirts and rear bar
Aero option front bar
TBO front lip
genuine n1 gtr bootlip
Flared front guards
Tint was removed for Regency
$12,000 ono
Car is in Adelaide
only selling cos i need the money
Call michael on 0400089213
genuine inquries only and no swaps
Edited by elf32
https://www.sau.com.au/forums/topic/353935-r32-gts-t-sedan/
  • 1 month later...
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
