Rb20Det $450
What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
What do the spark plugs look like after you tried to start it with everything connected?
Put the original injectors back in. See what happens.
So I put it to 3bar (43.5psi) while priming. It stays at 43.5~ as I crank shakes slightly. Ive also tried dropping pressure to see if that changes anything. I replaced the fuel dampener because I was troubleshooting the system along with the stock FPR (swapping them one by one to rule them out). But i only got up to changing the dampener and it started running again. Injectors are stock second hand. I did a bench test on both my original ones and the secondhand ones. The second hand injectors I have in the car now spray slightly stronger than my original injectors.
