The schnitty and mushroom sauce was excellent and the chips was sensational! :worship:
Anyone keen for dinner there again ASAP? :D
Yeah i was very happy with my schitty with pepper sauce. I am keen to hit it up again for dinner sometime soon Vu. :P
