After the rebuild I have a few items available to the needy. 10% of sales to SAU. Offers considered. Added some low res pc cam pics (I know, I'm cheap). Postage extra or as negotiated.
Added HICAS lock bar to offer - $100 plus delivery and $10 donated to SAU
Conrods x 6 - linished and polished sides, #3 (therefore all 6) need resize due to bearing run, this doesn't cost much at the machine shop - $100
Pistons stock 0.5mm OS x4 good cond 20K the other 2 are cracked - $50
Fuel pump stock GTS25t (replaced with GTR item) - $100
Nismo Steering Wheel - Nismo horn button Good Cond 3 spoke no centre pad bolts straight up to R33 GTSt - $100 SOLD
Greddy style fibreglass twin A pillar mount - 65mm black in colour, not used due to loss of vision on the racetrack, would be OK for road but doesn't suit me for race, fits over standard a pillar trim without needing to damage std trim- $120 SOLD
Hicas rear steering unit - $100 SOLD. I don't need it anymore:D I can also fabricate the Hicas Lock bar to get rid of rear steering, same price.
Stock Intercooler - $50 no hose fittings
Auto trans shifter surround Corbon Fibre finish - $30. Originally wasn't in great condition so I layed up carbon fibre over the base. Doesn't look as good as the pics, hence the low price.
Help me clean out the garage and help this great forum that has provided for me so well
As you can see I now have a digicam...but got it cheap:D
  • Replies 40
Not yet, still got a few things to finish off like pfc and tuning after run in. Plus finalising a few compatibility treasures I discovered.
No pics, runs from the base of the A pillar to the top of the A pillar. Never installed, just smoothed the holes for the guages to seat nicely.
Added some lo res pics. Not allowed to buy a decent camera so had to use web cam. Something to do with how much I spent on the engine build :(
I still have all the parts, was eyeing off the guage holder for some severe butchery but other jobs have given it a stay of execution. It's yours if you want it.
EnricoPalazzo, the wheel has a Hicas boss and fittings for the horn.
All negotiable.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
