My missus got home and rang me as soon as i got off the plane to tell me the GTR made it home safely and was snoozing in the shed..
Only 10 days to go until another drive encounting...
For sure mate.
Would be an awesome sight to see heaps of skylines (sensibly :blink: ) cruise through the hills.
Have to organise something soon. How do they operate? Having never been witness to a cruise or something similar, how are they organised? Any heat from Police (ish) looking cars?
Cheers,
Matty
there was a breaky cruise a few weeks/months back. it was an awesome cruise organised by SAU:SA. so join the club if your keen also there is a track day on the 11th of april if your keen to come out and have a look and chat :P
Welcome aboard Matt. I am glad it has gone to a good home....
Yes guys I have kept the HOSTILE plates which will be fitted to my next ride. Matt will be able to put his own mark on the 32...
PHATBOYcheers.gif ..NOTSAFE......SAFEAS.....my favourite one for mat is TTTC(take time take charge)for everyone at roxby..nyaanyaa.gifnyaanyaa.gif
on a serious note welcome buddie..next time we are on break worship.giftwisties here we come...u look good in my rear vison matt domokun.gif
Righto Ninj....
Rear vision mirror eh?? you will have to do a few more mods for me to be in the rear view mirror champ!! you will get :pwned: HAHAHAHAHAHA
I love the plate TTTC!!! :thumbsup:
I dont know what to do as far as a plate goes..
See ya soon Ninja ol Buddy!!
Matty
Righto Ninj....
Matty
I dont need a fast car coz its all in the drivingtongue.gif........seat right back, 1 arm out the window, other one on the ph and dumped hard with cut springs for the ultimate handling experince.thumbsup.gifthumbsup.gif so you can keep your pwned.gif sign but nothanks.gifnyaanyaa.gif
so i am guessing we are going to see this trash talk do the walk on the track sometime soon :P
LOL Krishy, we must be twins cause I was thinking the same thing.
Easy solution ladies, join a cams affiliated club like SAU-SA and join the list for the next track day.
You may even want to have a quiet wager on the side. :whistling:
PS: Martin's ride (in the right hands) will be a hard beast to overtake IMO ............having said that, I've seen a 34R with high 300kws get lapped by a 2000cc (relatively stock) 4cyl turbo
the trash talk just a bit of fun between mates.......i really got no idea how to drive i just swing on the steering wheel and hope for the best ha ha ha..will do a little track stuff but leave that up to the good drivers im more into straight line work.......
A track day sounds awesome fellas.
I would love to see how the car goes around the track but as i said to Martin when i bought the car, i am too afraid on breaking it!!
The little bit of banta between me and Dumpe (Ninja/Quentin) is all it is. He is a good mate of mine i work with.
Just a quick question, if i get new plates will the car still be Martin's Ride?? :glare:
Cheers
Matty
Cheers
Matty
After the first 7000rpm Launch it will be getting closer to being yours. :thumbsup:
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
