Sau Qld Skidpan, Welcome To The First Skidpan Of 2011, Saturday 9Th April, 2011
kicks off about 8.30 am and runs through normally till about 3.30-4.00pm with lunch break about 12ish
Damn, we finish at 4.
I'll be up for the next one.
Last spot has been filled, thank you to those attending.
List of attendees updated.
1. Rhinorebel - PAID - Thank you!
2. SPR34 - PAID - Thank you!
3. Toddlls - PAID - Thank you!
4. Grae35 - PAID - Thank you!
5. Boiracer (SAU ms) - PAID - Thank you!
6. mumslayer (SAU ms) - PAID - Thank you!
7. Fudgesical (QSC) - PAID - Thank you!
8. Chester180 (QSC) - PAID - Thank you!
9. BiG SeXY (QSC) - PAID - Thank you!
10. Scott (QSC Fudgesical's friend) - PAID - Thank you!
11. Fudgesical's other friend (QSC) - PAID - Thank you!
12. Elysium - (SAU ms)awaiting payment confirmation
13. Elysium's friend (SAU ms) - awaiting payment confirmation
14. Trd83 (QSC) - awaiting payment confirmation
anything else we need to know? like long sleeved clothes or any of that?
Mumslayer and myself will be heading up the highway from Caboolture area. anyone else heading from that way and wanna meet up somewhere on the way?
nope, nothing special, clothes is a must!! you dont want to get your bits burnt lol.
Nah no speacial clothing or helmet required. most of us will wear shorts or jeans if it is cold or something. A chair might be handy though, there never seem to be enough. there will be a bbq lunch and cold drinks available and if your not into that then the shops are only 5 mnis drive away.
we normally do breakky at the twin bp's around 6 and leave about 6.45-7am to head up if your interested. I live in the moronfield area as well but i normally meet the guys at bp.
cool. might not join yas for breakky. but will meet yas there to head up.
Shell on moronfield rd is cheap today + 8 cents of vouchers so i can fill my car.....now just gotta wait for a time of day where the lineup isnt onto the road....lol
Edited by boiracer
I know its been and gone, But for future reference i have a few questions
Roadcraft still have the rule that you must hold an Open C class license to hit the pan?
I know there is no surrounding houses, but is there a noise limit?
Does cars on pan have to be registered? can i bring mine up on a trailer?
Wet + 450rwhp+ = lots of wheelspin, do they go rank?
Cheers
  • 4 months later...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
