Set of 4 racing wheels and slicks
ROH DriftR's 18x8 & 18x9s with michelin slicks
2x 225 45 18 for fronts
2x 305 45 18 for rears will fit with rolled guards
will separate wheels and tyres
$100 per slick tyre
$100 per rim
ready for that track day!
$750 for the lot
also have spare fronts for $100 each
and spare rears 285 55 18 $100 each
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
