Got a 2000 model skyline gt manual with the rb25de neo for sale. Non turbo.
Got damage to front and small amount to rear. Front has hit the rad support slightly and smashed both headlights. Will need to replace front bar (may be able to be fixed, is broken along bottom, headlights, rad, fans, bonnet. Engine still runs, very small leak in radiator. Fan not touching radiator though. Has battery but is on charge atm, not sure if it is stuffed, not very old though. Front quarters are undamaged.
Chassis is all straight. Rear has also been touched, will need to replace boot lid, but spoiler is fine and bumper may be ok. Car has only done 104 ks. Has cannon muffler and apexi pod filter. Also has an alpine headunit with parrot bluetooth integrated, front usb, ipod cable connection etc worth bout $400. Has factory floor mats.
In decent nick, low k's, cigarette burn to rear passenger side seat base but other than that, pretty clean. Tyres are good with rears near new, has the factory rims.
Im happy to sell manual conversion including everything required.
ALL PARTS AVAILABLE. Let me know what you need and feel free to make non stupid offers for stuff!
Located near Frankston, VIc. Viewing welcome. Please contact 0422641010 for more info or to see the car.On a last note, Dont call after 10 at night, thanks
Parts already sold:
Sideskirts
  • Replies 55
What condition Is the center console lid an price
Cheers
Its in good nick, no marks, $30. Thanks
Heres a pic of the seats as requested. Thanks
Edited by griffonfamily
What condition is the steering wheel in and how much?
Also price on cigarette lighter?
Steering wheel in reasonable condition, just started to craze in a few spots, better than most I have seen. $80 with airbag. Cigarette lighter is sold.
After those clips holding the brake lines across the firewall of the enginebay. If they are in good condition lemme know how much you want :)
Its a matter of getting them off but all being well, $20 posted. Thanks
Would you have all 4 stock wheels?
One or two have very slight gutter rash, two tyres are near new, the other two are worn more on the inside but still would have at least 50% tread left. Want $150 for the set.
Hey Mate, I was after the 2 x plastic sail pieces behind the side mirrors ? (Triangle type of shape) also the clear plastic piece on the interior light (The front dual one)
Postage to NSW.
Thanks
Paul.
The plastic sails have had tweeters screwed to it but you can grab them if you want them for $10. And the clear plastic piece on the interior light for $20 posted. Or together $25 posted. Thanks
Postage to NSW.
Thanks
Paul.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
