  • Replies 55
Still have the shell but what are you chasing it for? The front rad support panel has been cut out though. Give me a call if you are interested. Thanks
Complete rb25de neo engine 2.5 vvti 150 kw with all ancillaries less flywheel and starter, with engine loom and computer $900. Only done 102,000 ks, in good condition. Pick up only from Frankston area. Thanks
Items Sold so far:
Rear wiper motor
Centre console trim around shifter
Front seats
Reverse lights
Sideskirts
Front interior light
Head unit trim surround
Centre console lid
Front indicators
Side repeater indicators
Radiator shroud and bonnet strut
Headunit
Boot/fuel cap cable
B pillar external trims
Interior rear view mirror
Gearknob
Headlights
Strutbar
Din pocket
Circled plastic trim next to headunit
Kick trim inside the door jam
bonnet heatshielding
Climate control unit
Passenger mirror
Exhaust from catback
Steering column trim surround
Gauges
Exterior black trim above front doors
Drivers side mirror
Gearbox
Clutch
Flywheel
Tailshaft
Spoiler
Clutch pedal and slave cylinder
Windscreen washer bottle pumps
Drivers and passengers side window regulators
Complete rb25de neo engine 2.5 vvti 150 kw with all ancillaries less flywheel and starter, with engine loom and computer now only $850. Only done 102,000 ks, in good condition. Pick up only from Frankston area. Thanks
Make me offers on any stuff thats left guys, the rest of the gear will be going on ebay soon
Items Sold so far:
Rear wiper motor
Front seats
Reverse lights
Sideskirts
Centre console lid
Front indicators
Headunit
Boot/fuel cap cable
Gearknob
Headlights
Strutbar
Din pocket
Passenger mirror
Gauges
Drivers side mirror
Gearbox
Clutch
Flywheel
Tailshaft
Spoiler
Front guards
Aircon lines
Front shocks and springs
Here is a price list and some pictures of the stuff left that is still for sale:
Rear subframe with diff,driveshafts and hubs $200
Rear calipers $50
Front calipers $50
Overflow bottle $20
Apexi pod filter $30
Fuel pump and tank $70
Windscreen washer bottle $15
Headlining $30
Door trims $50 ea including switches
Door actuators $70 pr
Steering wheel $40 (has quite a few marks but no major peeling)
Steering wheel airbag $100
Dash including passenger side airbag $120
Engine fan $40
Rear trims $50 pr
Rear seat $40 (has cigarette burn in base)
Heater core assembly $50
Aircon and fan assembly $50
Seatbelts $50 ea
Centre console trim $30 (without centre console lid)
ABS unit $80
Rear tail light $80 ea
Carpet $60
Brake master cylinder and brake booster $70
Power steering lines $50
Front part of exhaust to end of cat (including near new cat) $50
Genuine Floor mats - set of 5 $50
Wheels with good tyres $150
Rear shocks and springs $50
Handbrake assembly and cable $40
Front hubs $100
Front discs $40
Rear discs $40
Front cross member and rack and pinion $80
RB25de neo Engine including loom and computer $850
Starter motor $50
Steering column with key $50
Door, with glass $150 ea
Fuel door/flap $20
Heaps of other trim parts and stuff available - just ask 0422641010. Parts located in frankston, Vic. Prefer pickup.
Items Sold so far:
Rear wiper motor
Front seats
Reverse lights
Sideskirts
Centre console lid
Front indicators
Headunit
Boot/fuel cap cable
Gearknob
Headlights
Strutbar
Din pocket
Passenger mirror
Gauges
Drivers side mirror
Gearbox
Clutch
Flywheel
Tailshaft
Spoiler
Front guards
Aircon lines
Boot carpet and board
Rubbers around doors
Rear boot trims
Items Sold so far:
Rear wiper motor
Front seats
Reverse lights
Sideskirts
Centre console lid
Front indicators
Headunit
Boot/fuel cap cable
Gearknob
Headlights
Strutbar
Din pocket
Passenger mirror
Gauges
Drivers side mirror
Gearbox
Clutch
Flywheel
Tailshaft
Spoiler
Front guards
Aircon lines
Rear boot trims
Steering rack
Items Sold so far:
Rear wiper motor
Front seats
Reverse lights
Sideskirts
Centre console lid
Front indicators
Headunit
Boot/fuel cap cable
Gearknob
Headlights
Strutbar
Din pocket
Passenger mirror
Gauges
Drivers side mirror
Gearbox
Clutch
Flywheel
Tailshaft
Spoiler
Front guards
Aircon lines
Rear boot trims
Steering rack
Diff
Items Sold so far:
Rear wiper motor
Front seats
Reverse lights
Sideskirts
Centre console lid
Front indicators
Headunit
Boot/fuel cap cable
Gearknob
Headlights
Strutbar
Din pocket
Passenger mirror
Gauges
Drivers side mirror
Gearbox
Clutch
Flywheel
Tailshaft
Spoiler
Front guards
Aircon lines
Rear boot trims
Steering rack
Diff
Wheels and tyres
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
