  • 1 month later...
At today's EA's E3 press conference, it was revealed that Battlefield 3 will have an open beta across all applicable platforms beginning this September....EA has confirmed that Battlefield 3 will be released on October 25, 2011 for PlayStation 3, Xbox 360, and PC.
and vids without presentation - awsome in 1080p and vids have proper audio
I'll definitely be playing.
What platform are people going for? I have a ps3 with on 40" Sony (3D) LCD LED and a good PC ([email protected]/6gb Ram/GTX 470 and twin 24" Samsung LED LCD).
I have been playing BF2 and MW/MW2 on the PS3 previously, but Im wondering if I should make the switch to PC instead =/
What sort of graphics card do you guys think it would take to handle BF3 on high/max settings? currently have an intel i7 2.67ghz cpu, 6gb ram (computer seems to recognize only 4gb??),ATI hd4890 graphics card, some gigabyte motherboard. dont know too much about computers.
The reason your computer is only reading 4gb ram is because you're running 32-bit Windows. You'll need 64-bit to make use of the 6gb you have
Edited by Dani Boi
no kidding? its been pissing me off for years thinking i got ripped off
It was pissing me off too, having the pc recognize only 4th of ram. Time to grab that 64 bit version of windows.
The maximum amount of ram is actually theoretical:
2^32 = 4,294,967,296 ~ 4gb
2^64 = 1.844674407371e+19 ~ 18.4 billion gb
That's right, if we had unlimited ram space for our pc, we could theoretically have a maximum memory of just over 18 billion gb......... WTF?!?
Definitely need windows 7 x64 bit, otherwise you will only see even less than 4gb of ram.
Anyway, I'm thinking 6950 as a minimum for bf3 at 1920x1080.
anything less than that and you won't get absolute maximum.
They are making a new engine for this sure, but as if it won't get made properly which means even the slightly lesser than the highest hardware should make do just fine.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
