1992 VP BT1 5.0
Genuine BT1 with tags to show
Rebuit 304
All new gaskets
276 camshaft
LT1 springs
Rollmaster timing chain
New water pump
Gilmer drive pulleys
Upgraded coil
Bigger fuel lines
Custom fuel rail
Alloy radiator
Twin thermo fans
High torque starter motor
GENIE extractors
New 2.5 redback cat back exhaust
Rebuilt gearbox
Corvette servos
Stage 2 shift kit
Davis Craig transmission cooler
B&M pro ratchet shifter
3.9 gears, tight LSD
Silver drop tank with black straps
New Adjustable panhard rod
New bushes in all rear arms
HSV Clubsport interior
Custom door cards
New rear venetians
New Clarion MP3 head unit
Pioneer 6" splits in front doors
Pioneer 6" rear parcel shelf
Audioline 4 ch amp
Pioneer monoblock amp
Motor and gearbox are perfect!
Body is staight and clean, interior is immac. Rare VP BT1
$6,500 on VN SS wheels with Toyo tyres or swap
Melbourne S/E
0416 623 381 Call/SMS (NO PRIVATE CALLS)
Thanks
https://www.sau.com.au/forums/topic/357427-holden-vp-bt1-50-taking-swaps/
