There seem to be plenty in syd, have a search. Just make sure you go to one recommended on here. Otherwise you might end up with another mechanic horror story like many of us on sau.
Look/ search in the nsw forum, a fair few names came up in a thread maybe 6 months ago
https://www.sau.com.au/forums/topic/357470-mechanic/#findComment-5714528
