My misses is working till 8-9pm, she might come depending on the time..
ok so i plan on taking my front bar off this weekend, it's not sitting completely right (ill show you guys tonight) as far as i can see it's just plugged in etc, mind giving me a few tips? ill be going threw the DIY section once i polish the car.
it's not so much not having anyone to talk to, it's a few things, she wont be home till like 7:15 7:30 as she goes to the gym, and when she gets home, because i can't drive, she wont go out anywhere, she isn't the biggest person for social events
i know about HICAS, i was wondering if i should remove it or not, thats all, i don't plan on doing any sort of drifting, but would like to do mountain runs, so would it be adviced to remove it or not?
nah leave it in man, its a "save your ass if you play to hard" type of rear steer. V
ery handy for mountain runs......and if your car steps out and catches you off guard.
drifters in particular remove it cause it screw with how the car turns in. its not a nescessary aid. but if it aint broke, dont fix it :)
*not sure how this goes with more power and after market ECU's etc
Edited by boiracer
Yeah I wouldn't be disabling it unless you have a lock bar on it what if it isn't centred when you disable it?
Still sick and can't drive my baby hoping to be better before sunday.
I removed the hicas on mine, because it gets a little hairy when she wants to step out at 5000-6000 at 18/20psi. You can still run the hicas with an aftermarket ecu as it picks the speed signal from the dash. I promise guys I'll get out 1 night to meet and greet. When I get home most nights early I could not be f**ked heading out again. Lazy I know, but I will get out soon.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
