I'd look at breaking lease and moving somewhere cheaper for 8 months, but bottom line would be the same with fee's and moving costs... I'll keep looking...
Have you been advertising on the various real estate sites for a room mate? also try gumtree.
Morayfield this week the usual 7:30 time slot question is what does everyone have a hankering for? let me know what you want to eat.
arvos again:( but at least ill have my car, withdrawels f**king suck ><
+1 to clints pc brain, fixed my pc to be faster then my commodore.
I will be there next week though, hopefully!!
awesome line :thumbsup:
Speaking of pc's... Who wants to come over and assist with... Heck, put windows 7 on the machine i have here?
well turns out im not working today. but i have decided to put the back of the Line back together....hasnt had a back seat since coilovers were installed :(
i've got everything i need to make little extentions for the adjusters so i dont need to pull the back seat out every time i adjust the shocks (which ive realised makes a HUGE difference to the way it drives, and street soft will not work well on the track.)
so that will be my day
why have 2 cars if your strapped man that's 2x rego and upkeep that's just making a money pit, Any luck on the room mate front are you advertising everywhere including local shopping centre BB's?
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
