Sup pingers, long time no stir.
Hows the northern side faring?
Ive been pretty busy with work and babies lately as usual, dont get much time to play anymore! :(
No new mods, just in the process of respraying the wheels.
Pce
Welcome back for a short visit. Been a bit slow in here, its all happening on facebook.....
Because you're too cool for that sort of behaviour?
Apparently.... In other news. Hopefully ill hear back about the motor vehicle this week... If so I might pop down there with Clint to sus it out
Thought that you already had it back?
Lol Negative. There would be spamming galore if i had it back......
I havent really posted much in whoretown as im tring to keep it all central in the build thread.
Long story short it keeps breaking on the dyno. Valve Spings started leaking Wednesday last week so they are getting replaced.
Initial figures were 460hp on 14psi..... Will be interesting once we are running 27psi +
seems to have simmered down, and the old boys have a new whoretown to play in:) everyone wins
That's probably because anyone who disagrees gets deleted by the execs, I'll let you draw your own conclusions on that one.
If you're gonna be a dill and stir up crap and not even be a member there isn't going to be anything sympathy simple as that, if you can't play nice don't expect to be treated nice.
There are many of us who used to be members, and are not anymore for this exact reason.
+1 to this.
This place used to be about driving many years ago. Now its about politics and polishing the execs knobs.
Shit, the current execs weren't even in the community back when I remember it was thriving. Do the current exec board even drive skylines? You know, real ones that is.
+1 to this.
As a matter of fact every member on the exec board do drive skylines. To be honest I care very little for my knob being polished, I don't do anything to glorify myself I do everything for the club.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
