For sale is my much loved r32. It's a 1991 model with 110,000km's on the clock.
I was the first registered owner of this car in australia, it was complied and registered in November 2005. After plenty of searching for a rust free gtr this car came up. It was imported too Australia from a city in Japan that only snows around 1 week a year, hence no need to put salt on the roads to stop it from freezing which means no rust. The car was bought stock standard with the only modification was the cat back exhaust. All parts that were added to this viechle where done professionaly. Parts as follows:
2x HKS 2540's with HKS heavy duty wastegates
HKS dump pipes
HKS engine pipe
Apexi 3 1/2 inch exhaust
HKS intercooler plumbing
HKS 11mm Fuel rail
700cc sard injectors
HKS fuel regulator
Braided fuel lines with speedflow fittings
Splitfire Coil Packs
Bosch 093 intank fuel pump
Apexi air intake and filters
Apexi power FC computer with hand controller
Eboost 2
ORC 700hp twin plate clutch
Larger Alluminium 3 core radiator with electric thermo fan
New radiator hoses
All new heater hoses through out engine bay
All Boost hoses have been replaced
HKS timing belt change 2000kms ago
New water pump
New Brake master cylinder
Maas MKH 19x9.5 rims with kuhmo tyres with 95% tread
Tuned by Terry at Paramount performance in Toowoomba making 383rwhp @19psi. Taking into acount that Toowoomba has a high altitude. Tune is very safe and wasn't lent on.
Can't really think of anything eles that has been done. The car was bought with 101000kms on the clock. The standard clutch burnt out in it at 105000kms. All the work was done to the car while it was off the road. The car is in immactulate condition & is a very regretful sale. All new oils in diffs, transfer case and gearbox while I replaced the clutch. Engine oil & filter gets changed every 6months as i don't drive it enough to reach 5000kms. Some spare parts amd a spare set of 17inch work wheels will be included in the sale. The car jsut ticked over 11000km's.
I can not stress enough with how clean and tidy this car is, you will have to see it to believe it!
Plates won't be sold!!!
Asking for $20,000 ono.
Willing to help out interstate buyers
May consider swaps for a patrol 4x4 etc so i can tow my boat.
Anymore questions please phone
Leighton on 0439753418
post-34444-0-25667000-1300186294_thumb.jpgpost-34444-0-64516300-1300186391_thumb.jpgpost-34444-0-29951100-1300186428_thumb.jpgpost-34444-0-65075500-1300186472_thumb.jpgpost-34444-0-80315100-1300186540_thumb.jpgpost-34444-0-31666600-1300186601_thumb.jpgpost-34444-0-96013800-1300186640_thumb.jpgpost-34444-0-63987000-1300186717_thumb.jpg
https://www.sau.com.au/forums/topic/357551-qld-for-sale-r32-gtr-skyline/
Car was sold but fell through, the guy hasn't rang me to pic it up. It now has a current QLD RWC. It got picked to bits for the raod worthy and they only found a broken engine mount and an appreant throw out bearing noise until i explained to him how a twin plate clutch works and sounds.
It now has a brand new passenger side engine mount.
  • 5 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 2 months later...
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
