Yes should be fine. Just so you know all r33 gts, gtst and gts4 have the same structure and exterior panelling. Even a non turbo has pre marked holes in the engine bay for a side mount intercooler. So try posting this in the cosmetic and styling section.
https://www.sau.com.au/forums/topic/357815-r33-na-spoiler/#findComment-5719331
Will a r33 gtr spoiler bolt straight onto a non turbo 97 r33, or do you have to put the whole boot lid on?
Careful not to get the turbo-model spoiler, though.
It'll f**k shit up if you try put that one on.
Don't ask why... you really don't want to know. Just trust me when I say to avoid those turbo-model wings.
https://www.sau.com.au/forums/topic/357815-r33-na-spoiler/#findComment-5724158
I had no problem doing it, i replaced the bootlid with the wing attached straight swap.
https://www.sau.com.au/forums/topic/357815-r33-na-spoiler/#findComment-5724548
