hks step 2 kit...
i was considering selling it and buying a nitto 3.2- but i just can't bring myself to put a forklift donk in my gtr! :no:
i'll put one in the stag though... :yes:
ok, so my plan is to get some 5mm longer allen head bolts, seal the plenum with grey max silicon as the rubber seal is to big, even after being in the freezer. I measured the runner length against std and the OEM manifold is about 5mm longer than the Greddy. I will get a thermal phenolic gasket which will make up the runner length and insulate at the same time. I just hope the plenum fits and the OEM studs are long enough.
Matt
Matt
Get a hold of a o-ring slice kit:
http://www.rshughes.com/products/079340_00112.html
And make your own... Or use the one you have and cut a little section out of it then re-join it.
In the splice kit is a tool to cut o-ring material perfectly square. Then with two very clean very straight edges you can bond them with fine (good quality) super glue or o-ring glue... I make orings for harder/harsher/higher temp applications than this use all the time and I've had no problems so far.
If you get a phenolic gasket cut in any decent thickness- cut me one too pleeeeeease???
Cheers
Justin
    • Oh right, I didn't realise it was your car. Please do! Makes me feel better about mine. I also have a big scrape on the front left bumper where someone presumably used the wall to guide the car into a parking spot  But somehow all the funds go towards mechanical things and the cosmetics stay forever unfinished... Interesting, I don't think I have seen it before. But after seeing @PranK's rusty roofline on the BMW I'd probably leave it alone. Wouldn't want water to get in there.
    • Thanks mate, thought you might know the answer.
    • Infiniti US are teasing a manual Q50 as a way to refresh a (very old) model. https://torquecafe.com/manual-performance-sedans-arent-dead-yet/ Can't be too technically difficult given the Z has the same motor with a manual gearbox......here's hoping there is a JDM version we can import here, that would save me a world of headaches
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
