OP6 hiflow turbo (has OP6 printed on the rear housing) by turbologic in Wollongong, confirmed by fred himself. Still on the car, will be removed once sold. Has been on the car for over a year running 8-10psi. I pulled the intake off and found all intake fins are perfect, no chips or anything. very minimal if any shaft play, turbo still looks very clean and fresh. Welcome to come inspect or see it driving on the car
$800
will upload pics when i can
can sms 0416 129 811 for pics otherwise.
contact by phone or pm.
https://www.sau.com.au/forums/topic/358393-op6-hiflow-by-turbologic/
for all the kids that are going to tell me they can get their's hiflow'd new for $800,do it! i just rang Fred and he charges $1400 for his hiflow's + the price of an op6 turbo.
Yea its a dirrect replacment for r33 turbo. All your water/oil lines, dump pipe, inlet, etc all line up. It is currently in my 33.
As for its potential i'd say you could make 250kw+ on an rb25 with supporting mods. I currently run it on 8psi untuned tho so i can't exactly say, but i dont think its laggy.
Ad's; yea the turbo originally came from an r34, which has an op6 rear housing ( abit larger then a 33, so slightly longer spool time but capable of more power. )
Edited by nik.
So she isnt just a rebuild its a highflowed jobbie too?
Adam
Na, it was hiflowed which uses new wheels and bearings so its actually like a rebuild just using higher flowing internals aswell, so its capable of making more power. mate made 249kw on a GCG r33 hiflow, so being an OP6 i would say its capable of just a touch more, was also told it was fitted with the highest flowing internals it could fit in an r34 turbo.
hey, interested in the turbo mate, where are you located would like to come and see.
Located in wollongong, welcome for inspection at any time. Its on the car at the moment running ( altho untuned so you cant exactly see the potential of the turbo )
For anyone interested, on an untuned setup running 8-10psi and a standard dump, it seems to boogie at 3300rpm.
Oh okay, had no idea. I'd prefer a bush bearing anyway for multiple reasons. It originally came off one of the workers at JustJap car as he was upgrading and its been on my 33 since.
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
