oh right...but if the oil pump is faulty wouldn't the whole engine just go bang? because when the car was still driving the idiot light never turned on? even till the day where i ripped off the blown turbo...
Is the restrictor in the oil line? It could be blocked causing the initial turbo failure.
how about the intercooler piping? wouldn't it just not start and keep stalling?
either plumb plumb it in to the piping somewhere or unplug it and try get it to start in limp mode
and hypergear, cranking is not always enough. i cranked my motor for about 5 mins with the plugs out and didnt get a drop of oil up to the head or any pressure whatsoever, started it up and had pressure within a second
yer, made a slapper 30det and cranked it on the floor with no luck, then dropped it in the car and cranked it for ages (with plugs out), didnt get anything. started it up and got pressure straight away. fairly often cranking just isnt enough
besides, even if you do have a serious problem, starting the car for a few seconds isnt really gonna do any more damage unless something has gotten worse since last time it ran.
oh true hmmm ill start it up on the week end its just a bit wierd that my turbo was rooted from oil starvation but i was driving the car around for a bit then took it for a tune and on the dyno the turbo just died...thanks jonno
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
