Hey guys, Just stripping out my r34 track car!
here are a few pieces left i want to get rid of:
2 R34 Drivers Seat and Passenger Chairs
$150 each or $300 for 2
R34 Passenger seats FULL
$150 micky condition clean a few marks but can be dry cleaned :)
Passenger Rear Qaurter Panels
Rear Right: $50
Rear Left: $50
they both have a few scuff marks but very nice and clean
Rear Left: Top panel $50
Rear Right: Top panel $50
very clean
call me on 0411104489
Pick up only
https://www.sau.com.au/forums/topic/360662-r34-gtt/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
