Tried Clarke rubber and Kanga rubber to see if they have similar profile? They come to mind as suppliers worth asking.
I'm keen on replacing mine too, but I'd just want a new rubber not the whole thing.
Pretty keen on the rubber pending price. I was in the process of painting and restoring a spare cowl for just this purpose, but so far have been unable to find a replacement rubber strip.
Im still working on it, its a bit of a slow process...
I gave them a sample, cut of from my own rubber strip, which the supplier apparantly 'misplaced' so I gave them another and the supplier is sending back their closest match (all done via snail mail) should be a couple of days and they will give me a call and I'll go out and pick up the sample to see how it fits and gets some photos, measurements, comparisons etc... and pricing of course...
  • 1 month later...
nope Ive had no luck in finding a replacement rubber strip, only the OEM replacement cowling @ $220 each...
so I remove the deteriorated rubber strip, sanded and sprayed the cowling plastic & the wiper arms in satin black, looks good...
Got any pics? :) If it look's good I might just do that.
it does look good... I fully recommend everyone to do it...
I'll see what I can do about pics, but pretty much they are going to show a nicely satin black coated version of what you have...lol...
just make sure you prep them well before painting....
Correct . I will try over weekend to post a pic haven't done so before.
Hey mate sorry can't get pic upload having sync problems. But it pretty straight forward I did my brothers today all you do is remove the factory silicon/selant with thin flat head, wipe clean, squeeze black silicon into the channel of the strip that sits under cowl just don't o.d. it, push seal into place,wipe excess with wet finger or rag take your pick, place a weight on seal and allow to dry..... Voila.
are you saying you stuck the rubber strip down with silicon?
pics?
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
