I am after some guildance. Trying to decide what spring rate and sway bar to go for.
I am changing out my mines Ohlins for some custom coilovers specs are;
48mm valve monotube
External resevoir with sep rebound and compression adj, 800n range
Dual Springs(helper spring)
Steel bottom mounts
The car;
R33 GTR
RB32DETT(tad heavier in the front)
1590kg
Full Slicks 18x270
500awkw
Currenty has std sway bars but will upgrade to reduce body roll rather than a heavier spring.
Front coil?
Rear coil?
Front Sway?
Rear Sway?
Matt
Any idea what brand and valving you will be using in the shocks??
Really who ever is doing the custom shocks should be valving them and recommending a spring rate to get you in the ball park.
I'd be trying something between an 8.5-9 front and a 6-7 rear to begin with. Depending how sensitive you are to the car you may go up or down from there.
I'd also be getting a set of selby or similar bars locally. I like to keep to factory size +2mm if needed. Rather shorten the bar up to get use from it as opposed to going larger and increasing the weight.
No brand, 48mm mono valve. I asked for bilstein style valves 50/50
Have been looking at the Whiteline 24mm sway bars with Spherical mounts.
8.5-9 front and 6-7 rear looks good
Should I also look at a roll center adjustment Like these?
Matt
If you are not lowering the car alot (well you shouldnt as it will compromise suspension stroke), then you wouldn't need RCAs, and the only RCAs that work is the Moonface ones, all others are just for looks
Edited by ichi-go
All roll center adjusters are rubbish including those moon face ones.
Have a search for rollcenter in this section.
I've covered it many many times for various people in depth and basically.
To correct roll centers and all geometry with a lowered car you need to move more than the lower control arm like moonface and others do.
Couldn't find anything on Roll Center??
I still have the piece of paper to show this!
So Brad, you don't think getting the moonface rca's would help with bump steer either as they claim they do?
I'm undecided with whether to get moonface rca's or just oem replacement rod ends....
sorry for thread hijack :blush:
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
