I am after some guildance. Trying to decide what spring rate and sway bar to go for.
I am changing out my mines Ohlins for some custom coilovers specs are;
48mm valve monotube
External resevoir with sep rebound and compression adj, 800n range
Dual Springs(helper spring)
Steel bottom mounts
The car;
R33 GTR
RB32DETT(tad heavier in the front)
1590kg
Full Slicks 18x270
500awkw
Currenty has std sway bars but will upgrade to reduce body roll rather than a heavier spring.
Front coil?
Rear coil?
Front Sway?
Rear Sway?
Matt
Any idea what brand and valving you will be using in the shocks??
Really who ever is doing the custom shocks should be valving them and recommending a spring rate to get you in the ball park.
I'd be trying something between an 8.5-9 front and a 6-7 rear to begin with. Depending how sensitive you are to the car you may go up or down from there.
I'd also be getting a set of selby or similar bars locally. I like to keep to factory size +2mm if needed. Rather shorten the bar up to get use from it as opposed to going larger and increasing the weight.
No brand, 48mm mono valve. I asked for bilstein style valves 50/50
Have been looking at the Whiteline 24mm sway bars with Spherical mounts.
8.5-9 front and 6-7 rear looks good
Should I also look at a roll center adjustment Like these?
Matt
If you are not lowering the car alot (well you shouldnt as it will compromise suspension stroke), then you wouldn't need RCAs, and the only RCAs that work is the Moonface ones, all others are just for looks
Edited by ichi-go
All roll center adjusters are rubbish including those moon face ones.
Have a search for rollcenter in this section.
I've covered it many many times for various people in depth and basically.
To correct roll centers and all geometry with a lowered car you need to move more than the lower control arm like moonface and others do.
Couldn't find anything on Roll Center??
I still have the piece of paper to show this!
So Brad, you don't think getting the moonface rca's would help with bump steer either as they claim they do?
I'm undecided with whether to get moonface rca's or just oem replacement rod ends....
sorry for thread hijack :blush:
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
