Hey guys, selling my s14. Had it for about a year now but wanting something different.
09/1995 Nissan s14 200sx
Has SA rego until 23/04/2011. Will renew if I get a fair price.
Car is fairly stock:
Sunroof
Front mount
Navan kit
Exhaust
Lowered on king springs
135000kms
5 speed sr20det blacktop
Series two rear tail lights
Spoiler removed and holes welded up
Rolled rear guards
R32 stock rims painted black (not to flash to be honest – just sold my other wheels)
Resprayed a couple of years ago
Aircon also works perfect.
Poineer head deck with rear speakers and wiring for a sub
**Wheels not included in last pic**
Price: $9500 ono
Car is pretty clean from the outside. Inside is in pretty good condition aswell. Have used this for a while as my daily and hasn't let me down. In no real rush to sell, but price is negotiable.
Alex
Pm at this stage as phones at the shop.
https://www.sau.com.au/forums/topic/360825-for-sale-s1-s14-200sx-adelaide-sa/
Car is running about 7psi (Tested last week)
Rego also runs out 21/04/2011.
More pics taken today: (Car has a couple of drill holes from boost gauge)
Got my phone back also. Call/SMS for more info.
Alex, 0407140046.
Will take $8000 cash FIRM with rego not renewed.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
