1989/1990 Nissan Skyline R32 GTS-4 ( HICAS disabled )
Black
RB20DET
5 Speed Manual
156,000 k's.
Engine
Heavy Duty clutch.
BoV.
Apexi pod filter.
Near-new Master cylinder.
Turbo timer.
Full 3 inch from the turbo back to a 5 inch cannon.
Wheels/Suspension/Brakes
17inch ( Don't know what brand ) with 4 New tyres 235/45 17
Stock Brakes.
Stock Suspension.
ABS.
Interior/Exterior etc
GTR Full Bodykit
GTR Wing
Sunroof
Kenwood Head unit
Clarion speakers
Xenon lights
Interior is in really good condition, All electrics work
The car is fairly stock, I only drove it of a weekend and was covered up during the week, Turbo is @ 8-9 PSI and never been boosted, Also free boot lid.
Issue's
Bonnet needs a re-spray as it is peeling/stone chips.
Front bar has a bit of scrape damage, was on the car when i bought it.
Driver's side power window's switch needs replacing.
Thermostat is gone.
One of the best sounding RB's you'll ever hear!
The car ran smoothly never misses or anything, I had hopes of fixing it up but thing's but now i've moved states and need it gone.
Car is straight, no dents nor has it been crashed.
I'm asking 7k o.n.o, I'm open to offer's so don't be hesitant.
You can contact me on 0487 335 072
Car is located approx 20 mins out of Launceston - Tasmania.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
