I would be there sunday with bells on but im going on a cruise to the pacific islands in a week so need to spare the cash
No worries mate, will catch you on the next one
Cruise still on if it's raining?
Most probably no, will make a decision in the morning when I wake up. Will post here in the morning if it's not going to go ahead.
Just seen the thread
I own a silver 4 door R32
At the moment it's off the road doing some more mods, anyone know of people selling anything on this list let me know... I have cash...new or second hand.
750 - 1000cc injectors
Tomei Adjustable fuel pressure reg
Upgraded fuel pump (in-tank)
Exedy Heavy Duty Cushioned button clutch
Gearbox mount
ABS Pump
Full 3" exhaust
or if anyone knows how to convert the R32 speedo cable into an R33 any help would be appreciated....
Edited by MR.32
Gearbox mount
ABS Pump
Full 3" exhaust
Just buy a new gearbox mount for it mate, their not dear for aftermarket or even genuine :thumbsup:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
