33 could be off the road :(
32 isn't on the road as I have no monies :(
You can all donate to me so I can get it on the road in time for the cruise.
What's wrong with the 33?
Well with any luck they'll go to a good cause and not to defecting station.
Salvos easily better then defect station... Thought i was gona get done in the diahatsu for a baldy tire yesterday :/
Not good brudda....nothing's wrong with bald tires....they're safer because you don't have to try as hard when you want to drift ;)
Charity cruise is getting closer. Hopefully get the wires out of my toes 2 days before the cruise so I should be alright to drive. Did get the Vspec out for it's first drive in close to a month today to go down to Armstrong's to pick up some parts, one part was wrong but got the right one on the way now. And it was a challenge to drive really hurt my feet but was soo good to get in and go for a drive.
Sounds good Chris!
Should swap cars so that mine gets a break? I've realized I could never drive anything other than a GTR :(
Sounds good Chris!
Hahaha no the Vspec is very happy with the about it gets driven. Have done 500km's since my last oil change which was 3 months ago, now up to nearly 1000km's for the year. About time you came to your senses.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
