Spitting at 3500 rpm. :( Leaning towards coil packs or AFM. Other than that the car is running fine. Any thoughts?
Hey Kimbo man it's me, with the GTR from teh other night at Kat's ;) Welcome to forum btw...and the never boring world of the RB's haha
That's quite early in the piece for spitting =/ I'd start by going over everything with a fine-toothed comb - ie every single electrial wire and plug that you can see and the same for all your vaccum/air lines and pipes and hoses. Then I'd start taking things apart like, checking your spark plugs to see if they tell a story (there are some charts for plug discoloration etc)....if this "spitting" feels a bit more like a surge of some sort I'd also check/replace the fuel filter etc.
I have had coil packs go on me but they tended to wear down gradually, only missing in high RPM / high boost and then working their way down the rev range till they fail all together and your car sounds like a WRX ;-)
But yes, a good way to start is with a thorough inspection and cleaning of anything that is a sensor or an electrical connection. It's usually always something stupid like that...and if not, it's always best to start with this as it's the least expensive fix ;)
*snip*
Soooooooo why you no bring this frens along to the driving time?
We can have many many more fren. Always only two or three or four car come for driving.
Is very boring like that you know?
Next time you call all you fren to coming ok?
Many love and for long long time,
Nick
Ah bru I only met him the other night - pulled up behind his car and almost made romance explosion in my pants =/
But yes, Kim you're welcome to come along for a spin...it will make Nick a very happy man for long time ;)
Well V8 Nick should have his monstrosity going very soon...even tho one of us will have to drive it for him :P
^This. This brings all the lols to the yard.
Quiet Tony, but yes it is finished but bloody auto electrician is booked out and can't get to it untill next week :(
Took a few happy snaps yesterday, A V8 is starting to look normal in there to me :/
So when do the Chev badges and southern cross sticker arrive? :P
Pfft sif chev badge.... Gota get onto Steve from Wrapture to make me up some chev vinyls for the coil pack covers/to replace my nismo stickers ;)
Edited by Captain Natro
Hey bud, yeah as soon as I have 5 mins to scratch I will be going over the engine with a fine tooth comb and checking everything. Fingers crossed I can nail the problem. Cheers for all the advice from everyone.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
