Ok who ever is doing the rain dance can seriously stop now. So keen to get the Vspec out for a play in the hills but they are all flooded in parts at the moment
you own a 4wd.. use it! :P
You kents and your boat comments :P
Why exactly is a 33 GTR a boat? Keeps up with a 32 in every way even tho it's heavier....and with f*kked rear shocks at the time too? Take that v-spec boy ;)
In my experience the driveability of the 32 and 33 GTR really comes down to the driver....I've seen both go very well....both roll the same, slide the same and at the same points when pushed too far etc etc...
It's not how you "talk about ur car on forums"....it's how you race it :D lol
Why exactly is a 33 GTR a boat? Keeps up with a 32 in every way even tho it's heavier. It's not how you "talk about ur car on forums"
Sooo Wednesday night TSO drag night at willowbank is what your getting at here isn't it Tom :yes:
But I think certain other people on here may not be manly enough for such an outing :P
Says the manly man who is too tired to have a beer of a Friday night :P
I'll be keen for a squiz when I get a new clutch and maybe some other stuff done.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
