Dafuq has your diff got to do with it?
Also, why is the banner ad at the bottom here an ad for Asia Romeos?
Because he has being meaning to fix it for almost a year now!
You guys ever dealt with a f**ked boot hinge where one side of the boot lid sticks out past the tail light? A mate pushed down on it yesterday with something stuck under the hinge and like yeah the lids fine just need someone's knowledge to fix it... Pay one of you guys to have a go? Please lol
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
