Ok, I'll be waiting for you at Lakeside next saturday.
Hell no, that place is where nice cars go to die.... I refuse to put my car on that track.
But I ripped straight past you around the turns at QR.
Ill fix my battery clamp, then bring it on (for the first two laps then im unable to stop the car lol)
This particular ls1 can corner :P
Yeh I got your back Nick ;) lol
It can corner. Cornered very well after fitting the coilovers. But was a little drunk at the time also.
I don't have your back but captain. Tom is doing a great job of being all over it ;)
Chris, I might have to check out this clay bar of yours that you mentioned.....was just checking out some youtube vids, never used one before.
Its good shit mate. You can borrow mine if you want
Yeh I wouldn't mind trying it out out on a little patch - I take it that you have to use it with a form of liquid polish as a lubricant?
You would be correct sir. I have a detailing spray to use with the clay bar
Nice! Did I ever end up showing you the dents in my bonnet?I dare say that I'm gonna have to get the whole bonnet fixed and resprayed at some stage...it doesn't look like it from a distance but it has at least 5 decent hail stone dents in it and some pretty bad stone chips on the leading edge above the grill =/
Lubricant spray for clay bar? Sawft! Mix some car wash and water in a spray bottle and that will do. ;). Just needs to be a slippery solution.
Yeh it's a type of polishing compound with a wax mixed in...may as well polish/wax it while you're scrubbing away
that's the way we do it at work. The detailing spray came as part of the clay bar kit I purchased, otherwise I would be using car wash
Yeah you have shown me the dents on the bonnet. I'll give you a quick quote now to fix it all. Thousands
Clay strips off all wax and polish. You're essentially waxing and then ripping the wax straight off. Clay takes it back to pure paint.
You are correct sir
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
