Ok, I'll be waiting for you at Lakeside next saturday.
Hell no, that place is where nice cars go to die.... I refuse to put my car on that track.
But I ripped straight past you around the turns at QR.
Ill fix my battery clamp, then bring it on (for the first two laps then im unable to stop the car lol)
This particular ls1 can corner :P
Yeh I got your back Nick ;) lol
It can corner. Cornered very well after fitting the coilovers. But was a little drunk at the time also.
I don't have your back but captain. Tom is doing a great job of being all over it ;)
Chris, I might have to check out this clay bar of yours that you mentioned.....was just checking out some youtube vids, never used one before.
Its good shit mate. You can borrow mine if you want
Yeh I wouldn't mind trying it out out on a little patch - I take it that you have to use it with a form of liquid polish as a lubricant?
You would be correct sir. I have a detailing spray to use with the clay bar
Nice! Did I ever end up showing you the dents in my bonnet?I dare say that I'm gonna have to get the whole bonnet fixed and resprayed at some stage...it doesn't look like it from a distance but it has at least 5 decent hail stone dents in it and some pretty bad stone chips on the leading edge above the grill =/
Lubricant spray for clay bar? Sawft! Mix some car wash and water in a spray bottle and that will do. ;). Just needs to be a slippery solution.
Yeh it's a type of polishing compound with a wax mixed in...may as well polish/wax it while you're scrubbing away
that's the way we do it at work. The detailing spray came as part of the clay bar kit I purchased, otherwise I would be using car wash
Yeah you have shown me the dents on the bonnet. I'll give you a quick quote now to fix it all. Thousands
Clay strips off all wax and polish. You're essentially waxing and then ripping the wax straight off. Clay takes it back to pure paint.
You are correct sir
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
