Keen to head out to a lunch run in yours ;)
Can meet at tbar HQ before you leave.
I've made a promise to the wife that the old girl stays in the garage until we part ways...
I am sure we can work something out
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
