Breakky. This may be moved to the 14/07 as we have a display at the Lakeside classic. We need 100+ cars for that so can you guys get there?
I dunno. Will be making the trip down on the 18th for the dinner.
I need to be back in Toowoomba by 6 pm on the Friday. Was just planning a down and back trip on the Thursday as I don't have anywhere in Brisbane to stay/store the GTR safely for the night to stay on the Thursday Night
