I can prolly make it. But won't have the old girl. She will be gone by tomorrow arvo :(
I don't mind meeting up at Tbar HQ or if Tom comes, I'll accept being picked up HA
Yar I'll see how I'm going....I constantly have been having stuff get in the way of my car work the last 2 weeks or so, tis rather annoying! Really need to paint the remaining 2 wheels lol
So are we game for tomorrow or what? :)
Old girl got picked up by her new owner yesterday so there's no way I can join for our usual session (temporarily anyway).
Was so hard to hold back tears watching her drive away...
Ah man but you'll get to drive around in an Evo soon yeh?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
