o/ give a homie a wave!
New old girl? Caldina?
Can do but your car and its colour (best colour btw) is so low key, I only spot you once you're really really close.
Yea, Caldina is the "new" old girl. She's being promoted after a couple years in the shadows.
Awesome man, good luck with the Evo's!
As for the pulling over business - each to their own I guess.
You won't be disappointed in the evos, I went for a run in an evo 7 awhile back and shit the thing went for a stocker
Okies...each car had their pros and cons. Haven't made up my mind. Gonna think it over real hard and decide if I want to proceed or wait for more cars to come onto the market. If I decide to go ahead, gonna get the owner to take the car in to a specialist to give it a full once over (mechanical, electrical, exterior/interior). If the owner says "No", I'll walk.
An Evo isn't really something I truly want. It's merely a compromise with the little lady and my current circumstance.
Anyone keen for a drink and lunch on the 4th?
Always keen if I have spare time. At this point, I'll say Yes!
Hopefully we'll actually get to do something this time :P
Great Leader has spoken, guys. Get to it! :worship:
Haha I'd rather partake in events that require two balls ;) (don't take that the wrong way you pair lol) ....reference to that trackdays meme :P
I'd actually do mini golf but that's as far as those old people extreme sports go :D
I haven't been in the silver Slart
Greg ( #@Sick_R31 ) has been in the abomination twice
And Tom in it twice, once with a broken box
That's because you are scared of a real car that can corner.
Gladly I have not been in the abomination yet.
yeah i'd be f*cking terrified if I was in that thing and saw a corner coming up
Only time I have been for a ride in it was after I fitted coilovers to it. I was drunk at the time. Did sh*t myself on one corner though
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
