Only time I have been for a ride in it was after I fitted coilovers to it. I was drunk at the time. Did sh*t myself on one corner though
I don't know what your all on about the car handles fantastically... It's only the stopping that is questionable
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
