Hard man to please Nick :P Maybe you have to get a 7 instead?
Will try not a get a 7. Prefer 8 for the slightly better drivetrain. A 4.5 grade french blue would be a straight buy for me tho :D
My sister is an import broker for mainfreight in brisbane so i get awesome deals :yes:
"YOU" get awesome deals. Us peeps on the fringes get nothing... :unsure:
I need someone that can do me dirt cheap 235/45/17 tires, don't care about brand.
Taken from EvoOZ. Give this guy a call. Rob@Neta Tyre and Auto.
2/49 Toombul Rd Northgate Brisbane
07 32662333
He had some mad feddys for sale in May and could possibly do it again if you ask I guess.
His May prices:
235/45R17
Kumho KU36 235/45R17 $199
Federal 595 SS $102
Federal 595 EVO $149
Federal 595 RSR $179
Kinforest KF550 $72
Durun Sport 1 $99
Hankook Z222(rs3) $199
I'd go RS3s dude. Best tyre there for the money. You'll smash your time at the drags!
Yes thats true ;) Not bashing the Feddys.
Just pointing out that at those sizes and prices, the RS3s are the best value.
Premier time attack tyre those ones...so super grip plus decent wear.
Skids on those tyres would be madness tho. Throwing money down the drain.
We all need to do a little cruise down to QR for the midweek sprints! There were some STUPIDLY fast skylines there yesterday running mid 50's!
Chris, there were engine bays there that rivaled yours in cleanliness...on a track/street car :O
Man there was a guy there who looked just like you...you don't have a brother or something who goes there? It was uncanny lol
I plan on going down more often during the week man - I'll let ya know next time, sorry bud
...btw, wednesday's down there kick ass - not so packed out!
Apparently the 595 SS are hopeless in the wet. RSRs on the other hand are great!
Thats the opposite to my experience, The 595 as they are now known are reasonable, but the RSR is pretty bad, and they are also pretty bad when cold. A good all rounder is the 595EVO.
The guys running them at the sprints in the wet at LP were complaining that they were like skates. Not much fun at all.
Stupid South Africans don't get brad Pitt joke :rant:
Haha thonges and all ey, mayb I have a twin :D
It must be man....because all jokes aside, it was freaky. I thought it was you for a sec lol
Yep I run the Evo's on my 33 R and they're quite good...especially at around 33-34psi (tire pressure lol, not boost) They're definitely my best set of rubbers yet and they seem to also be lasting a lot longer than my old tires.
It was pissing down and they were attempting track laps on a street tyre, There are not a lot of tyres out that would be good in that situation! When I think bad wet weather tyre I think of something that is dangerous at normal driving speeds, like the Nexens I had once :O holy shit it was about 5 near death experiences per trip.
The 595 ss' are total crap in the wet, when I can bag them up at 110 when I hit boost and the road is just damp something is wrong. The guys running the Achilles 123s all had good times so I'm thinking about a set of those next.
That's weird I have no issues in my car but it's awd. never had an issue in the sil80 either. different setups I guess Edited by Bunta
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
