I have found the solution to this.
Do her in the kitchen. :) doesn't matter how knackersd she is, everything is less than 3foot away. :)
Solid logic.....i see you've played this game before
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
