Ah that's good to hear a-bomb Nick...yeah you want to at least be able to pull up again. I can live with that you don't want to do corners anymore but being able to brake harder than you can accelerate is always a must for me! Out-braking and out-handling wins as many races as out-running :P
Edited by tommis85
I have a engagement party :(
Also incase you missed it I picked up some goodies through the week:
Cusco 2 way mechanical LSD (goodbye crappy 3.5 nastiness hello awesome tear your face off 4.11 acceleration! :devil: )
And I've broken my number 1 rule of "brakes only slow you down" and gone and purchased r32 Gtr calipers front and rear with slotted rotars... (So now I can stop lol)
Good on ya dude.
Bout time you listened :P
Cusco will be a bit rough round the edges and you'll clunk almost everywhere. Clutch in when you drive past coppers and you'll be fine :P
Am wondering if the NA 33s had the drum brake setup on the rear as if they don't you'd have to get that setup as well or you'll be without a handbrake.
Funny that you should mention that because I was thinking the same thing this morning. I haven't done anything for the last week or so because I re-sprayed my wheels - they're all good again now. Must say they looked quite horrendous indeed! Looked like it was just a colossal failure of the clear coat :/
Not sure if I'd head back out to it man - it's just all yank pretty much. Would be good to see some more JDM there, or even some German/Italian muscle and what not. So yeah not sure Nick - see what happens I guess.
Dude, we are about the only JDMs in town that do try to make an effort LOL
We aren't gonna see any more :P
If we don't rock up, then there's no representation.
Went to that Nandos meet with 180 Nick....we definitely need to get a couple of us together next time round. This time they really had a fantastic turn out there!!
So what can we do cruise wise in the mean time? A trip to a pub lunch would be nice....seeing that you're mentioning food Clint ;)
Pub lunch I can always do....well not always but most times :)
Would really like to find time to do a Happy laps too. I wanna see what this car can do.
Are there any of the new people around?
Saw lots of cars there I've never seen before. Bigger JDM representation this time around too and most of them were different from the first time I went.
Plenty of new people around just hanging around in their little cliques. We need a few more bodies so we can have ours :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
