Hey hombres.
Occasionally my tacho does this annoying thing where it will flick to a 6 o'clock position and sorta stay there. Video below should give you an idea on what it's doing when I turn the key. Only thing video doesn't show is that when driving with the tacho like this, if engine rpm goes about roughly 4000rpm the tacho begins to climb backwards up to 7000rpm, at which point it will stay there even when I hit the limiter until I allow revs to drop again, at which point it will drop back down to 6 o'clock.
The first few times this happened it sorta woke up and fixed itself when I hit ~4000rpm...
Engine runs fine when this is happening, so it's either a problem with the ECU aux out, or a problem with the tacho motor. If my tacho is dying, I don't really care.
https://www.sau.com.au/forums/topic/361273-tacho-being-a-shit/
tried searching? Tacho Showing Over 9000?! - Skylines Australia
mines started doing this too. give the dash a bash when it happens, if it bounces around when you hit it, you know its just some connection or resistor in the tacho playing up. apparently theres also a calibration screw on the back of the tacho and giving it a few turns back and forth to loosen it up can help.
or take the tacho out and send it a gauge place, theyd be able to fix it.
Yeah I figured it'd be an issue with the tacho itself. I think I tried bashing the dash once but it didn't do anything, also WAAAAYYY back when my car was stock the tacho just stayed on 0 once or twice....
Ah well, as long as everything that matters is working fine, then I'll just leave it.
Cheers :)
yeah exactly. The ViPEC doesn't have a hand controller (although I could sit a laptop in the passenger seat, F&F style)...I don't care too much if my tacho doesn't wanna work, as long as it doesn't affect anything else :)
You don't need a laptop, just replace the tacho with a "danger to manifold" warning light. Fixed
    • Or the brand new throwout may be unhappy...
    • Thanks for the linkie. Certainly always a great deal of help when people post comparisons like these, but I think for now I'll stay away from any semi slicks. I did go ahead and order the sportcontact 7. My buddy has them on his modified A4 and he keeps saying how good they are. For my intended purposes these will probably work real well. I'll report on them once I had the chance to try them out
    • Talk about noisy. Even when I still had the Tomei under the car I could distinctly hear the tires rolling. And I doubt I ever will need maximum grip like on a track. My GTR will maybe never even see the 600hp mark and I need to get used to the car quite a bit before challenging the limits of its handling. For the next winter storage I think I will get a set of these rubber drive-on thingies that have a tire shaped base. Those supposedly really help prevent flat spots.
    • Well our climate is definitely way less hot overall and the weather can be quite picky at times. I just know that during normal road use or even spirited drives there is no way I'd be able to consistently stay in the operating temperature, and constantly changing the tire pressure would also be a royal pain.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
