bit more complicated then that.. it has been tried.. anything from japan is gonna be costly.. thats where matty is based.. and i can see smaoked reverse lights causing a defect issue..
$180 for front indicators to be tinted , aswell as a $1000 for tail lights? thats a terible amount of money to be spending on cosmetics. seriously just buy some black acrylic and also some clear. mix it to a ratio that you are happy with and just spray them your self. i did mine , definitly makes the car look more stealthy , as long as its a black car. why spend all that money ?
my 2 cents, cheers
na outside man , not inside lol. that wont work at all . outside is the visual you want to see , you arent going to be looking at whats inside. thats an alternative , those night shades.
but be careful because iv seen people use night shade on their cars , they are more of cheap look . looks kinds crappy in my opinion. thats why iv used black and clear , seams to look much better than that crap.. bare in my mind iv got a spray gun/compressor to do all that.
good luck.
Edited by sky017
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
