Have for sale my 2 month old never used 28 row oil cooler, braided lines and sandwich plate. Brand is unknown but was purchased from Ryan at ISC. Pics can be posted on request. Paid $300 Selling $250 O.N.O (as stated never used - so its BRAND NEW) Contact on : 0430 362 050 or P.M <BR><BR>In S.A can post at buyers expense
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
